[FINAL RELEASE] Tuya Zigbee mmWave Sensors (code moved from the Tuya 4 In 1 driver)
Please update the driver manually to the development branch version 3.1.3 (link)
I had a similar device sitting in my drawer for quite a long, it is made by another manufacturer, but yours seems to be of the same type :
  • endpointId: 01
  • application: 90
  • inClusters: 0000,0003,0500,0001,0400
  • manufacturer: _TZE200_2aaelwxk
  • model: TS0601
  • softwareBuild: 0122052017
  • tuyaVersion: 2.1.0
AliExpress : (link)
I have added just another 'Device Profile' group:
After updating the driver, select 'LOAD ALL DEFAULTS' and click the Configure button above.
I didn't have much time to test everything, but the first tests were OK, and this battery-powered mmWave sensor seems to be working fine with my setup!
I will add the battery level reporting in the next update.
@iEnam If I am not wrong, you had a similar battery-powered mmWave device?
