Filtrete 3M-50 (CT50)
All,
i have the filtrete 3m-50. When i was using smartthings i originally had it working over z-wave by using the addin module. Somewhere along the way that module stopped working and all i had was wifi module. i still wanted it integrated with smartthings and i ended up using this: Filtrete 3M-50 Wi-Fi Thermostat. Version 2.0 Released 12/17/2016 - Community Created Device Types - SmartThings Community
it allowed the thermostat to communicate over wifi. Any way to get this working with Hubitat?
got my device to pair and it esems to work great!
i went back and tried to install the zwave module i had (along side the wifi module). I realized from the general device exclusion thead i asked about that my zwave module was most likely still paired to smartthings and i had to exclude it. Thanks for the minimote trick! i was able to exclude it and then add the thermostat via zwave. it didnt find it by default but then i switched it to the generic zwave theromostat and the stuff i want to work works! Fan on (didnt see an off)/heat/cool/set temp/off
