I have just migrated my Hubitat C-8 to Z-Wave JS tonight and the built-in Fibaro Wall Plug driver shows the wrong switch state when the plug is turned on from Hubitat. The plug turns on (the load is powered), but a few hundred milliseconds later the device state flips to "off" and stays there until “Refresh” is pressed. All my Dashboards show the same wrong state.
Environment
- Hub model: C-8
- Platform version: 2.5.2.127
- Z-Wave stack: Z-Wave JS (recently migrated from legacy)
- Z-Wave firmware: 7.18.1
- ZWave-JS version: 15.29.0
- Device: Fibaro Wall Plug Type G (UK) - FGWPG-11
- Driver: Built-in "Fibaro Wall Plug
Issue
- Fibaro Wall Plug is off.
- Turn it on from the device page or a dashboard.
- The load powers on, but the device state ends up as "off".
- Expected behaviour is switch = on
- Actual behaviour switch = on, then immediately off (twice)
Debug Log (Switching on from Hubitat)
on()
SwitchBinaryReport: SwitchBinaryReport(value:255)
Office Lights switch is on
BasicReport(value:99) B
Office Lights switch is off
executeBasicGetCmd()...
Analysis
The plug correctly reports "on" with SwitchBinaryReport(value:255). It then sends BasicReport(value:99), which is also "on" (per the Z-Wave spec, 1–99 and 255 = on, 0 = off), but the driver records it as "off". It looks like the driver treats only 255 as on. Under the legacy stack this didn't happen, so Z-Wave JS appears to be delivering the Basic "on" value as 99 where the driver expects 255.
Pressing the physical button on the plug reports correctly (single SwitchBinaryReport(value:255), state = on).
Configure and a hub power-cycle did not change the behaviour.
Possible Fix
In the Fibaro Wall Plug driver's BasicReport/BasicSet handling, treat any non-zero value as "on" (value > 0), rather than only 255. I have ~49 of these plugs, so a fix in the built-in driver would be much appreciated.
