Fibaro switches or relays .. and a bit of a mess!
When I first got In to home automation via smartthings I purchased a range of inline fibaro switches and relays.
At the time I didn’t know that the relays were different to the switches. However they are both up and running via smart things. I have around 15 of these.
However, I’m not sure what I have where. In smart things it was a bit of trial and error but I’ve got a mix of different device handlers.
To make things a bit more complicated I’ve got some dual switches (or relays!?) that are controlling single switches.
So, my question is; is there a way from a device identifier I can query to figure out what I have where ie is it a switch or a relay and is it the single or double (obviously where it’s controlling two sources it’s a double but I know I have at least a couple of double switches controlling single lights).
I see that there is now a ported dual switch fibaro device handler but not a relay device handler and no single fibaro relay or switch device handlers so I’m trying to figure out what I can / can’t port to hubitat at the moment.
Thanks for your help !!
If they're not listed on the "compatible devices" post in the wiki, then you'll have to trial them to see.
You'll need to exclude them and then put into pairing mode, however that's accomplished. I think your best bet is try one of each type, see if they auto-select the driver for 'em or just say "device" upon pairing. If the latter, post the details of the device and the staff here can associate it with a driver.
