Need a little help. I have added a Fibaro Swipe to Habitat. The status on the contact page shows the push button activated when swiped but very often will not trigger any routines. I made a simple routine to turn on kitchen light to test but still may only work 1 out of 5 or 6 tries. I've tried reloading driver and rebooting Habitat. Anybody else experience this or have an idea for a fix. Thanks for any help.
The first step is to rule out a problem with your "triggering" device, the Fibaro Swipe, which it sounds like you may have done already. If not, of course, a lack of a triggering event from that device will prevent any apps that look for that event from running in response to it (or the lack thereof).
After that, enabling all logging for the app in question is a good first step. Then, look at the output of Logs, filtered to just that app, for clues. If you need more help here, sharing those Logs (tip: screenshots avoid awkward formatting from copy/paste) plus a description or screenshot of the actual app you're using (e.g., a rule or whatever else) would be helpful.
Thank you for responding. The below are all the times Ive swiped for trigger and the one time it performed the action. I did hit configure on the device page at one time but still no change
Z-Wave Poller PollingCloset SensorMaster Bathroom SensorGarage FreezerSwipeLights Out
dev:3052025-10-19 06:06:30.656 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:05:53.042 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:05:28.263 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:04:43.322 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:04:16.687 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:03:53.792 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:03:38.015 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:03:10.759 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:03:02.859 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:02:55.378 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:02:19.577 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:01:57.377 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:01:04.453 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:00:41.981 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:00:41.829 PMdebugBattery 100%
Apps and devices
Z-Wave Poller PollingSwipeCloset SensorMaster Bathroom SensorSwipe Kitchen Light
app:4632025-10-19 06:11:09.727 PMinfoAction: Exit Rule
app:4632025-10-19 06:11:09.688 PMinfoAction: On: Kitchen Light
app:4632025-10-19 06:11:09.621 PMinfoTriggered: Swipe pushed 3
app:4632025-10-19 06:11:09.618 PMinfoEvent: Swipe pushed 3
Apps and devices
dev:3052025-10-19 06:11:09.499 PMdebugSwipe Left / Button 3 Pushed
dev:3052025-10-19 06:11:02.168 PMdebugSwipe Right / Button 4 Pushed
dev:3052025-10-19 06:10:58.523 PMdebugSwipe Right / Button 4 Pushed
dev:3052025-10-19 06:10:51.486 PMdebugSwipe Left / Button 3 Pushed
This is the rule
