If anyone is using this configuration could you share your wiring and driver configuration? I have the drivers installed and configured but the external sensor is not reporting temperature changes. Thanks.
I don't have the new version but have the old. Did you connect them after you included them? If so that's your issue, the have to be connected before you include them too the network.
That's probably it. Let me remove everything and try again. Thanks.
Edit: that did it.
Really late to this post but I want to say thanks for this as I was having issues with fibaro smart implant and 2 temp probes, having them connected when pairing fixed it.
