UPDATE - This now appears to be working - don't know what I did - it just appeared to start working with no errors in the log. - So this issue is resolved - I'll leave this post in case someone else has a similar issue.
I want to use the Fibaro Smart Implant to trigger my garage door - I just want to use it as a zwave controlled dry contact relay.
I paired a Fibaro Smart Implant and used the Fibaro FGBS-222 Smart Implant driver.
I used all the default settings and did a "Save Preferences" and "Configure".
It created the 5 child devices.
When I go to the "Fibaro Smart Implant Switch Out 1" device page, and press the "On" button nothing happens and I get an error in the log - see below. How can I fix this?
I also did a zwave remove of the Smart Implant, deleted the FGBS-222 drivers, reinstalled the FGBS-222 driver and then re-paired the Smart Implant (using the FGBS-222 driver). - -Same result - see debug log below
dev:10022024-03-03 01:13:59.322 PMerrororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_christi999_Fibaro_FGBS_222_Smart_Implant_994.componentRefresh() is applicable for argument types: (com.hubitat.app.DeviceWrapper) values: [Fibaro Smart Implant Switch Out 1] (method componentRefresh)
