I have a brand new Hubitat C-5. I started learning a couple of devices. As I was learning this motion sensor, which is FGMS-001 ZW5 v3.3, it only shows up as an unknown generic device. Because of this, no config options or events seem to be available. The Hubitat documentation states this device is supported. Help please..
BTW...I have also tried putting Hubitat in secure learning mode for all and tried again. Still only recognized as a generic device.
I'm not sure why it didn't allocated the right "TYPE" to the device it should do really but I've found occasionally things don't always go as we would wish.
At least you know how to get round this in the future.
Is it working OK?
Post the information (manufacturer, inclusters, etc) displayed in the data section at the bottom of the screen so they can add that fingerprint to their built-in driver.
they remain active(like if I keep moving) for 30 seconds then change to inactive (If I just move once) until they detect me once more, But what i need is just a momentary response unless they detect constant movement
I'll have to recheck mine but off the top of my head they go active they remain active for maybe 15 - 30 seconds. Then depending on the config will re-trigger.
To test open the device on your mobile and make sure it shows inactive. Walk in the room and make sure it goes active and then walk out.
Does it then go inactive after a period of time.
I have set mine to re trigger after 30 seconds which sounds suspiciously like you have observed.
