Hi all,
Does anyone know a way I can push "16" to parameter 21-26 on the Fibaro Key Fob?
Also, has anyone gotten double or triple click to work on it?
Thanks,
Josh
Hi all,
Thanks,
Josh
I don't have one, but typically you can temporarily substitute the Basic Z-Wave Tool driver for your normal driver, make the change, and then change back. Chances are thereafter you have to be careful about using commands like "Configure", because it could change it back.
