Hi all,
Is Fibaro FGK-10x Contact sensor/Temp with firmware 2.5 compatible with the current Hubitat firmware please?
I'm not able to get it work with temp sensor nor without it. I got just the battery status and nothing else.
Please help.
Thanks in Advance
ErvinN I gave up on these some time ago. I have 3 or 4 and they worked somewhat with smart things. In Hubitat I was never able to get any more than you as in battery status. Great idea but they seem to be unstable. If I had to guess the firmware gets corrupt easily.
Thank for sharing your experiences with mentioned device.
All 5 of mine work great on Hubitat. They are all used for fridge and freezer internal temperature sensors since you can attach an external temp probe to them. They do show firmware version 3.2 though.
waynespringer79 can i ask what driver did you use?
Fibaro Door/Window Sensor 2 Driver
thank you
