Fibaro Door/Window Sensor 2
Evening all
I have 3x Fibaros attached to pressure pads for my staircases. They worked well with the stock drivers on STT. I have moved them across to HE but struggling to get sense from them.
I have used the Fibaro Door/Window Sensor 2 driver than comes in firmware 2.0.4.113
Here are some snippets from the Logs -
Any suggestions to get these up and reporting?
Well get this sorted in the next release.
Thanks MIke
For the short term I will use a couple of Virtual Switches and Hub Link
I have the same issue still after upgrading to 2.0.4.117, using the built in fibaro driver.
Anyone else have this sensor working with HE?
Logs when opening door:
dev:432019-01-20 12:26:38.041 amdebugignore: Crc16Encap(checksum:65535, command:5, commandClass:113, data:[0, 0, 0, 255, 6, 23, 0, 204, 244])
dev:432019-01-20 12:26:33.836 amdebugignore: Crc16Encap(checksum:65535, command:5, commandClass:113, data:[0, 0, 0, 255, 6, 22, 0, 255, 197])
--- Live Log Started, waiting for events ---
Crc support for this driver will be in release 2.0.5
Is 2.0.5 released for european version yet? My HE cannot find any updates..
Yes it is as I updated to 2.0.5.113 yesterday.
I have some fibaro door/windows and a motion sensor I will get around to test given the 'Fibaro Z-Wave drivers: Added CRC decode to support legacy devices' fix
Had to reboot hub to update. Now the sensor report open/closed egen opening door:)
