Fibaro Dimmer 2 FGD-212
I progress forward with trying my different devices in the hopes to migrate to Hubitat but apart from Aeon simple smart switches everything else I am running into issues.
I have 5 of the Fibaro dimmers and have tried the inbuilt as well as a handful of community drivers but none work fully. The closest working on is by Robin Winbourne but on higher dimming levels the switch keeps turning off.
has anyone got these devices to fully work on C7?
My bad, apparently you have to recalibrate the dimmer after inclusion into Hubitat.
This measures the circuit and sets the max raw band it will work up to, afterwards it defines that as your 0 to 100% dimming level.
Homeseer must be quite smart as I never had to manually initiate this, where as Hubitat required me to use the zwave tool and set forced calibration.
