Please make sure to update the hub to the latest version. Virtual thermostats are supported:
Thank you. Yes it works.
Just a note for those using Advanced vThermostat device, which does not show up on EZ Dashboard list. Once the Advanced vThermlostat device is created, go to the device and change the device type to Virtual Thermostat. Then it will works perfectly on EZ Dashboard..
Once you have added the device to the EZ Dashboard, you can change it back to Advanced vThermostat device. The added tile will remain on the dashboard and works fine.
The reason behind the missing attribute, is the "thermostatFanMode". To get around the issue, on the device set the "thermostatFanMode" to "on". This resolves the missing attribute, which the tile required. Also changed the "supportedFanMode" to only "off", as there is no fan on my heater.
Can we please get this fixed? The garage tile still does not match the lock tile.
More feedback on EZ Dashboards, this time re: button tiles... When a Button tile contains more than six (in this example, 7, but happens with 9+) buttons, no matter how large I resize the tile, only the first six β whether 2x3 or 3x2 layout β ever grow to "full size":
The 7th, 8th, ... and beyond remain "vertically scrunched" as shown:
Expected behavior: Buttons resize in unison.
Is it possible to get more then 12 columns for desktop: There is a lot of wasted space on each side:
Hi, Finally tried the new dashboards. Much easier drag and drop and multisensor view is nicer.
For feedback:
- I'm with the others above on the alignment/padding adjustments.
- Could we get separate device label font, data/value font and icon size values to adjust? I'm a big fan of larger temp/humidity values with a smaller device descriptor. This new setup makes both the same sized font.
- I also noticed that in multisensor mode, the tile shows units for temp and humidity, but when I switch to just temperature, *C is dropped. Humidity loses the % as well.
- Webcore graph tiles don't show up in the selection menu to add to the dashboard.
Thanks!
