I've got a laptop open to Add Device / Zigbee and I hit Start Zigbee pairing. Then I go around an reset a bunch of devices. While running, it shows the devices that were found and and reconnected to previously joined devices.
It would be really helpful if the list of reconneced devices stayed around after the pairing timer expired, and it was only cleared out when I once again pressed Start Zigbee pairing again.
+1 - if I may modify your feature idea, I'd really like an On/Off/Time length option for the 'start zigbee pairing' - it timing out after 90s isn't long enough. My HA dongle has a 'enable pairing' and disable pairing feature, so it does seem doable,
I'm also now in a 'hunt' mode trying to figure out the same old problem I've had and going through my mesh one at a time...
I had to rejoin nearly a dozen devices yesterday. I did everything through the phone app since it's easier to carry around than the laptop, which in turn is much easier than dragging around the desktop on an extension cord and ethernet and oh, the CRT monitor!
