Feature request: implementing device # on high load?
Not sure if the title makes any sense.
If a hub has a "high load" event, that there is accessible info on what caused the event?
Last revision of firmware has my C4's producing events, mentioned above.
A high load is not necessarily caused by a device. It could be, and looking at Logs > Device Stats would give you clues. But it could be an app (Logs > App Stats would give you clues there) or some other service on the hub that may or may not show up associated with an app or device.
You might be confusing this with the "too many events" threshold for a device, which will also generate a notice in the same place if reached. That message already includes what you're requesting.
