Feature Request: Clone Virtual Devices
Hi Everyone -
I believe that this would be something useful for everyone.
If you need to setup for example:
  • 10 virtual switches, that have all the same capabilities, inputs, states.
    It would be great to CLONE de devices. New Id's, new dni, but virtual switch, like the RM cloning feature.
  • 10 IP curtains (virtual device, with own driver).
    They are all IP based, the only thing that changes is their IP or ID.
    Clone the device, with it's own driver, config, and create new ID, new dni.
Or if it was easier, to export and import, like Rule Machine.
What do you think @gopher.ny ?
Thanks!
I'm just curious what this saves, it is only a few clicks to create a virtual device. How many clicks would you expect cloning to take? What is gained?
You pick a device to clone, instead picking of a driver to use
You name the clone instead of naming the new virtual device
I can't see any use for this, unless I am missing something. Are you looking to be able to create 10 clones in one swoop? I don't think there is much of a use-case for that to warrant it, and you still have to name those ten clones in ten steps.
The built-in Preference Manager app might be useful for your situation.
Had a few minutes. See if this will work for you: https://raw.githubusercontent.com/thebearmay/hubitat/refs/heads/main/apps/vDeviceClone.groovy
I think I misread what you are looking for... you want to create a new device of the same type and copy all the current device states into that new device. That is totally different, and not how your post read for me. It reads that they "all have the same" but doesn't mention copying values to them, just that the devices are the same.
That could be useful then, so sorry for misinterpreting your post, but your post just never clearly says that you want to copy values, just that the new drivers will have the same inputs and states, which just looked to me like creating a new virtual device.
Thanks @jgbLC for your comment! The idea was not to copy just the preferences in a device all across devices, but facilitate the creation of new devices which had same information in them, like IP address, commands, and other values already stored in the device. But anyways, thanks for the suggestion!
@chrisbvt no need to be sorry!! I should be sorry for not be clear enough with my post. I really appreciate the fact that you took the time to analyze, and comment.
It is exactly what you mentioned in your last post - and what @thebearmay started coding.
Let's see if this helps anyone else.
I was now even thinking, a way of deleting multiple devices by checking them, and no need to go into each one and removing them. I know that there is no method actually for deleting devices from an app that are not childs from the app. At least non-zigbee/z-wave/paired devices. But maybe if anyone has any idea? Think that could help time too.
Now!
@thebearmay ! You got it 99% right! Please accept my feedback to your code, and verify anything else you want to change or improve, just
I got your code, used some AI to fix errors and add some features.
It's possible now to clone any device, not only virtual ones.
It get's the proper driver by entering the namespace, and clones the device keeping
the preferences, and values needed.
Example:
In 1 click you can create 20 IP motor curtains (Virtual Device, using a specific driver for the curtain), that they all share the same IP address, have the same properties, but the only difference is their CurtainID to be sent.
The same can be done for any other virtual devices that really have information inside in their preferences that can be re-used.
The virtual switch was a simple example, and you got it right!
THANKS for the time, effort!
Below the updated code for the app for you and anyone to collaborate.
  • Virtual Device Clone
  • Licensed Virtual the Apache License, Version 2.0 (the "License"); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an "AS IS" BASIS, WIyTHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
  • Date Who Description
  • Description: Clone an existing device into N devices using the SAME driver as the original.
  • HHorigian:
    • Handles built-in "Virtual *" drivers by trying namespace "hubitat" automatically.
  • — Namespace-Probing
    • Clone an existing device into N child devices using the SAME driver as the original.
    • Copies data values, current attribute values, and (where possible) preferences/settings.
    • Learns/auto-remembers successful (typeName → namespace) in state.nsMap
    • Bulk aliases text box: "Driver A=nsA; Driver B=nsB"
    • Tries case variants for candidate namespaces automatically
definition(
name: "Device Clone(Any Driver)",
namespace: "thebearmay",
author: "Jean P. May, Jr.",
description: "Clone any device into one or more child devices using the same driver, copying attributes and settings.",
category: "Utility",
iconUrl: "",
iconX2Url: "",
iconX3Url: ""
preferences { page(name: "mainPage") }
def version() { "1.3.4" }
/* ========================= Lifecycle ========================= */
def installed() { logInfo "Installed v${version()}"; initialize() }
def updated() { logInfo "Updated v${version()}"; unsubscribe(); unschedule(); initialize() }
def initialize(){}
/* ========================= UI ========================= */
def mainPage() {
dynamicPage(name: "mainPage", title: "Device Cloner (v${version()})", install: true, uninstall: true) {
section("Select the device to clone") {
input name: "selectedDev", type: "capability.*", title: "Device to clone",
multiple: false, required: true, submitOnChange: true
section("How many clones?") {
input name: "cloneAmt", type: "number", title: "Number of clones to create",
defaultValue: 1, range: "1..100", required: true
section("Naming (optional)") {
input name: "baseName", type: "text",
title: "Base label for new devices (default: original label/name + index)", required: false
section("Advanced options") {
input name: "allowAllDrivers", type: "bool",
title: "Clone any driver (advanced) — skip virtual-only guard",
defaultValue: false, required: true
input name: "preferredNamespace", type: "text",
title: "Preferred namespace to try first (optional)",
description: "e.g., 'hubitat', 'TRATO', 'community.ns'", required: false
input name: "extraNamespaces", type: "text",
title: "Extra namespaces (comma-separated, optional)",
description: "e.g., 'TRATO, community.ns, another.ns'", required: false
input name: "nsAliasesBulk", type: "text",
title: "Bulk aliases (type=namespace; type2=namespace2)",
description: "e.g., MolSmart - GW3 - RF=TRATO; My Driver=community.ns",
required: false
input name: "applyNsAliases", type: "button", title: "Save aliases"
if (state?.nsMap) {
section("Known driver namespaces") {
paragraph state.nsMap.collect { k,v -> "${k} → ${v}" }.join("
section("Logging") {
input name: "debugEnabled", type: "bool", title: "Enable debug logging",
section("") {
input name: "cloneNow", type: "button", title: "Clone Now"
if (state?.lastMsg) {
section("Result") { paragraph state.lastMsg }
/* ========================= Button Handler ========================= */
def appButtonHandler(String btn) {
if (btn == "applyNsAliases") {
saveBulkAliases()
state.lastMsg = "Aliases saved."
logInfo "Namespace aliases updated."
return
if (btn == "cloneNow") {
def dev = getSelectedDevObj()
if (!dev) {
state.lastMsg = "Please select a valid device first."
logWarn state.lastMsg; return
    def ctrlType = (dev.hasProperty('controllerType')) ? dev.controllerType : null
    if (ctrlType && !settings?.allowAllDrivers) {
        state.lastMsg = "Device appears non-virtual (controllerType=${ctrlType}). Enable 'Clone any driver' to proceed."
    try {
        String msg = cloneDevice(dev)
        state.lastMsg = msg
        logInfo msg?.replaceAll(/<[^>]+>/,'')
    } catch (Throwable t) {
        state.lastMsg = "Error while cloning: ${t?.class?.simpleName}: ${t?.message}"
        logError state.lastMsg
/* ========================= Resolve Selection ========================= */
private def getSelectedDevObj() {
def sel = settings?.selectedDev
if (!sel) return null
def candidate = (sel instanceof List) ? sel.find { it != null } : sel
if (!candidate) return null
if (candidate?.hasProperty('id') && candidate?.hasProperty('deviceNetworkId')) return candidate
Long id = null
if (candidate instanceof Number) id = (candidate as Number).longValue()
else if (candidate instanceof CharSequence) {
    String token = candidate.toString().split(',')[0].trim()
    if (token ==~ /^\d+$/) id = token as Long
return id ? getDeviceById(id) : null
/* ========================= Core: Cloning ========================= */
private String cloneDevice(def selectedDev) {
int created = 0
int clones = safeInt(settings?.cloneAmt, 1); if (clones < 1) clones = 1
String typeName  = selectedDev?.typeName ?: ""
String nsFromDev = selectedDev?.typeNamespace ?: ""
if (!typeName) return "<p>Could not determine the driver's name (typeName). Aborting.</p>"
// Pull fullJson to replay preferences/settings if possible
Map fullJson = [:]
try {
    httpGet([uri:"http://127.0.0.1:8080", path:"/device/fullJson/${selectedDev.id}",
             headers:["Connection-Timeout":600,"Accept":"application/json"]]) { resp ->
        fullJson = (resp?.data ?: [:]) as Map
    logDebug "fullJson loaded with ${(fullJson?.settings ?: []).size()} settings"
    logWarn "Unable to pull fullJson for ${selectedDev}: ${t?.message} (continuing)"
    fullJson = [:]
// Build candidate namespaces (ordered)
List<String> nsCandidates = []
String nsPreferred = (settings?.preferredNamespace ?: "").trim()
if (nsPreferred) nsCandidates << nsPreferred
if (nsFromDev)  nsCandidates << nsFromDev
// Learned alias comes first if present
String learned = lookupNamespaceAlias(typeName)
if (learned) nsCandidates.add(0, learned)
// Extract potential namespaces from fullJson (best effort; often empty)
def maybeNS = []
maybeNS << (fullJson?.driver?.namespace)
maybeNS << (fullJson?.device?.typeNamespace)
maybeNS << (fullJson?.metadata?.namespace)
maybeNS << (fullJson?.typeNamespace)
nsCandidates.addAll(maybeNS.findAll { it instanceof CharSequence && it.toString().trim() })
// User-provided extra namespaces (comma-separated)
String extras = (settings?.extraNamespaces ?: "")
if (extras) nsCandidates.addAll(extras.split(',')*.trim().findAll{ it })
// Heuristic for MolSmart naming (kept from earlier guidance)
if (typeName?.toLowerCase()?.contains("molsmart")) nsCandidates << "TRATO"
// Built-in fallback for virtuals
if (typeName.startsWith("Virtual ")) nsCandidates << "hubitat"
// Expand case variants and dedupe (order preserved)
List<String> withVariants = []
nsCandidates*.toString().collect{ it.trim() }.findAll{ it }.unique().each { ns ->
    withVariants << ns
    withVariants << ns.toUpperCase()
    withVariants << ns.toLowerCase()
nsCandidates = withVariants.collect{ it.trim() }.findAll{ it }.unique()
logDebug "Driver: typeName='${typeName}', candidate namespaces=${nsCandidates}"
String baseLabel = (settings?.baseName ?: selectedDev?.label ?: selectedDev?.name ?: "Clone")
(0..<clones).each { idx ->
    String suffix   = (clones > 1) ? "-${idx+1}" : ""
    String newLabel = "${baseLabel}${suffix}"
    String newName  = "${(selectedDev?.name ?: selectedDev?.label ?: 'Device')}${suffix}"
    String newDNI   = buildUniqueDNI("${selectedDev?.deviceNetworkId ?: selectedDev?.id}-${now()}-${idx}")
    def nDev = createChildTryingNamespaces(nsCandidates, typeName, newDNI, [name:newName, label:newLabel])
    if (!nDev) {
        logError "Failed to create device '${newLabel}' with driver '${typeName}'"
        return // skip this iteration
    // Copy device data values
    try {
        selectedDev?.data?.each { k, v -> if (k != null) nDev.updateDataValue("$k", "$v") }
    } catch (Throwable t) { logWarn "Could not copy data values: ${t?.message}" }
    // Copy current values for each supported attribute
    try {
        selectedDev?.supportedAttributes?.each { attr ->
            def aName = attr?.name
            if (aName) {
                def aVal = selectedDev.currentValue(aName)
                if (aVal != null) nDev.sendEvent(name: aName, value: aVal)
    } catch (Throwable t) { logWarn "Could not copy attribute values: ${t?.message}" }
    // Copy preferences/settings (best-effort) from fullJson
    try {
        fullJson?.settings?.each { s ->
            if (s?.name && s?.type != null) {
                nDev.updateSetting("${s.name}", [value: "${s.value}", type: "${s.type}"])
    } catch (Throwable t) { logWarn "Could not copy settings: ${t?.message}" }
    created++
    logInfo "Created clone #${created}: ${nDev?.displayName} (DNI=${nDev?.deviceNetworkId})"
return "<p><b>${created}</b> device(s) created.</p>"
/* ========================= Creation helper ========================= */
private def createChildTryingNamespaces(List nsList, String typeName, String dni, Map props=[:]) {
def nDev = null
// Try (namespace, typeName, dni, props) for each namespace candidate
for (String ns in nsList) {
try {
logDebug "Trying addChildDevice(ns='${ns}', type='${typeName}')"
nDev = addChildDevice(ns, typeName, dni, props)
if (nDev) {
logDebug "Success with ns='${ns}'"
rememberNamespace(typeName, ns)
return nDev
logWarn "addChildDevice failed with namespace '${ns}': ${t?.message}"
// Very last resort: 2-arg overload (typeName, dni, props)
try {
logDebug "Trying addChildDevice(type='${typeName}', dni='${dni}') [2-arg overload]"
nDev = addChildDevice(typeName, dni, props)
if (nDev) {
logDebug "Success with 2-arg overload"
rememberNamespace(typeName, "2ARG") // sentinel
return nDev
logError "Final addChildDevice attempt failed for '${typeName}': ${t?.message}"
return null
/* ========================= Namespace memory & bulk aliases ========================= */
private void rememberNamespace(String typeName, String ns) {
if (!typeName || !ns) return
state.nsMap = (state.nsMap ?: [:]) as Map
state.nsMap[typeName] = ns
logDebug "Remembered namespace: '${typeName}' → '${ns}'"
private String lookupNamespaceAlias(String typeName) {
return (state.nsMap ?: [:])[typeName] as String
private void saveBulkAliases() {
String bulk = (settings?.nsAliasesBulk ?: "").trim()
if (!bulk) return
bulk.split(/\s*;\s*/).each { pair ->
def kv = pair.split(/\s*=\s*/, 2)
if (kv.size() == 2) {
String t = kv[0].trim()
String n = kv[1].trim()
if (t && n) {
state.nsMap[t] = n
logDebug "Alias set: '${t}' → '${n}'"
/* ========================= Helpers ========================= */
private String buildUniqueDNI(String candidate) {
String base = candidate?.replaceAll(/\s+/, "_") ?: "clone-${now()}"
String dni = base
int salt = 0
while (getChildDevice(dni)) { salt++; dni = "${base}-${salt}" }
return dni
private Integer safeInt(val, Integer d=0) {
try { return (val == null) ? d : (val as Integer) } catch (Throwable t) { return d }
/* ========================= Logging ========================= */
private void logDebug(msg) { if (settings?.debugEnabled) log.debug "${app.label}: ${msg}" }
private void logInfo(msg) { log.info "${app.label}: ${msg}" }
private void logWarn(msg) { log.warn "${app.label}: ${msg}" }
private void logError(msg) { log.error "${app.label}: ${msg}" }
And so the legend continues... :wink: :+1: :grin:
