Because there are times when you want to provide upper or lower bounds on a variable's value, it would be helpful to have MIN(a,b) and MAX(a,b) at our disposal.
I realize the list of available mathematical operations has been kept pared to the most basic and oft-used variety, with further limitations imposed by the Rule Machine UI (e.g. favoring binary operators over open-ended ones like avg(a,b,c,d,...)). And it goes without saying that fancy calculations could be done using Hub Variables in the context of, say, WebCoRE, etc.
But a simple MIN(a,b) and MAX(a,b) (and, heck, why not AVG(a,b)) could simplify instances where you need to place limits on values -- for example, the HeatSetpoint for a Thermostat, which should not exceed MaxHeatSetpoint. I assume they would also be simple to implement from a coding perspective.
Thanks!
