Feature: Add 'Pause Rules: Button Controller' to RM actions
I'd like to be able to instruct Rule Machine to pause/resume specific BUTTON CONTROLLER rules, the same way it can with other apps' rules:
Currently, I can only Pause or Resume those rules manually (which is nice, but not sufficient for my purposes). I'd like to automate the pausing of certain button rules, for instance, that Turn On All Lights whenever the home is on generator power. Right now, RM handles that for every other instance except Button Controller.
NOT TO BE CONFUSED WITH UNRELATED TOPIC Feature Request: Pause Button Controller!
FWIW, you should be able to "pause" a button rule using an if/then in the command:
If: Running on generator
Then: Send/speak message "Can't turn on all lights while we're running on the generator"
Else: Turn on all lights
I do something similar with my button rule for fans:
The thing is, I would have to modify dozens of rules in Button Controller to put this into effect. Was already well underway modifying some Room Lighting automations when it occurred to me it's far simpler just to create an RM rule to do all the pausing/resuming based on the status of my Boolean flag.
"...modify dozens of rules..."
Makes sense if your use-case for this is that extensive. :slight_smile:
