Oh that's interesting, I didn't think of adding the fauxmo bulbs directly. I just did try that and couldn't get it to work, probably because I don't know what device network ID to use. What do you use?
When I configure real bulbs and then switch the app to faux bridge and get fake bulbs working, the app's settings show some strange thing for the faux bulbs, which I'm not sure I can directly configure with virtual devices, and I'm also not sure if it's even work or if these settings only work as a "happy accident" because of something unexpected happening in the hue integration app.
Also, if I somehow did add the individual bulbs as virtual devices, I'm not sure how the
Here are those settings, 788CEC is real and 824100 is faux
bridgeRefreshCount0
bridges{uuid:2f402f80-da50-11e1-9b23-001788788cec={deviceAddress=50, ssdpTerm=urn:schemas-upnp-org:device:basic:1, serialNumber=001788788cec, hub=1, name=Philips hue (788CEC), verified=true, ssdpPath=/description.xml, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-001788788cec, idNumber=788CEC, networkAddress=0A010AFC, mac=001788788CEC, ssdpNTS=null}, uuid:2f402f80-da50-11e1-9b23-bcddc2824100::upnp:rootdevice={deviceAddress=76d, ssdpTerm=urn:schemas-upnp-org:device:basic:1, serialNumber=bcddc2824100, hub=1, name=Philips hue (824100), verified=true, ssdpPath=/description.xml, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-bcddc2824100::upnp:rootdevice, idNumber=824100, networkAddress=0A010AEA, mac=BCDDC2824100, ssdpNTS=null}}
bulbHash296b8d1017cc6009b89a8b8ac7c26630
bulbRefreshCount2
bulbs{11={hub=null, modelid=LCT004, name=wee you, id=11, type=Extended Color Light, remove=false}, 12={hub=null, modelid=LCT004, name=macbook, id=12, type=Extended Color Light, remove=false}, 1={hub=null, modelid=LCT004, name=switch, id=1, type=Extended Color Light, remove=false}, 2={hub=null, modelid=LCT004, name=ps4, id=2, type=Extended Color Light, remove=false}, 3={hub=null, modelid=LCT004, name=dex, id=3, type=Extended Color Light, remove=false}, 4={hub=null, modelid=LCT004, name=restart, id=4, type=Extended Color Light, remove=false}, 5={hub=null, modelid=LCT004, name=pc, id=5, type=Extended Color Light, remove=false}, 6={hub=null, modelid=LCT004, name=cinema, id=6, type=Extended Color Light, remove=false}, 7={hub=null, modelid=LCT004, name=gamemode, id=7, type=Extended Color Light, remove=false}, 8={hub=null, modelid=LCT004, name=fire, id=8, type=Extended Color Light, remove=false}, 9={hub=null, modelid=LCT004, name=pc audio, id=9, type=Extended Color Light, remove=false}, 10={hub=null, modelid=LCT004, name=ps3, id=10, type=Extended Color Light, remove=false}}
FWIW I tried hueBridgeBulb with DNI of 0A010AEA/1 and 0A010AEA/103/1 (103/1 as used by the real bulbs) but that conflicted, tried all kinds of stuff, nothing works.. the faux hub's network ID is shown by hubitat as BCDDC2824100 (and "active") so I also tried that with /1 /103/1 and nothing.
Maybe I'm close, appreciate seeing your setup. If this doesn't work though I will probably abandon the hue emulation altogether and just go with a more direct route
