Faulty PIR Sensor (Neo Coolcam)
Hi All,
I have 6 of them https://www.aliexpress.com/item/1005002363522926.html?spm=a2g0o.order_list.order_list_main.41.51d41802Wxu94G
And one of them is not detecting the motion properly. I have to top on the lens to get the motion detected.
Any idea how I can fix them?
Only two things I can think of. 1 there is a bad connection somewhere in there so you tapping is tripping the sensor into working. 2 sensor has its detection set distance set to zero...
Other than that you could try re-pairing the dodgy one without deleting it from the hub.. But if its 1 it won't make a difference. You might have just got a bad unit so I'd maybe think about returning it.
2 you can enable advanced options I think it is and check minimum detect distance on one of the working units and compare with the dud, they should be the same...
