One of my Homeseer variable speed fan switches died. They don't make them anymore. Looking for a 1 gang...speed adjustable only (separate switch for light) device to replace it with. Paddle not a toggle.
THANKS!
THANKS!
Inovelli has a Zigbee and a Matter over Thread fan switch, both pretty similar aside from the fact that some of the advanced features likely aren't usable over Matter yet.
Thanks for the quick response… I’ll look in to them.
I have been using the GE/Jasco Zwave fan controllers for almost 10 years. This fan switch has 3 speed adjustments and is only for AC powered fans.
https://www.amazon.com/Jasco-Assistant-Compatible-Required-14314/dp/B07WSG4FN4
I use the same and have for about a decade. Reliable.
I used to have a ton of the old GE toggles. Pretty much rock solid. I think it's about 1/2 the price of the Inovelli as well. I usually like having all the bells and whistles as I can in a device, but the needs for this ceiling fan location are pretty simple.
Fan controller here is Leviton ZW4SF. They are for ceiling fans with a wall power switch and pull chain speed settings. Made a RM app which sets the power to 100% for x seconds then powers back to maintain desired setting. This gets the blades turning much quicker and is similar to how the pull chain worked. OFF, High, Med-High, Med, Low. Use Ernie's custom driver.
These look awesome. Thanks. I have separate 1 gang wall switch openings for the light and the fan. For me this is probably overkill...but good to know about!
