I got the following errors in the log. There is no water leak at the washer, dry as a bone.
Error for phone number is asking for a country code. I don't know what that is for US.
app:13472019-04-06 08:13:02.111 pm errorjava.lang.Exception: Invalid phone number, numbers must start with + and be followed by country code and phone number (waterHandler)
app:13472019-04-06 08:13:02.067 pm warnAlert Water Washer Leak Sensor wet
And you saw the alert in HSM? The water leak sensor showed that it was detecting water at that point? (you can look in the history of events for the device)
Correct. When I looked at the UI, HSM showed an Alert like the pic above. But when I opened up HSM there was no Alert shown at the top. Ex. If you have an alert and you open HSM at the top is a big red Alert, there was none.
But both of those screens are the UI and both of those screens are HSM.
That screenshot is too small to see completely. Do you mean in the Apps list vs in the App detail?
And I didn't say past logs. I said events list. Go into the device, at the top there is an Events button. That will show you a list of all the events for that device.
So you see my problem though...that screenshot you posted above cannot possibly be from the apps list because the same thing is not above it on both screenshots.
