Failing update from 2.4.4.156 to 2.5.0.153
Hubitat C8
I had a working hub with version 2.4.4.156 in a home I am currently away from. I did a database rebuild on reboot and verified that there was about 1GB of space available on the device IIRC.
After the reboot, I went through the update process and attempted an update to 2.5.0.153. That update stalls on the “Extracting Update” step.
I am remote and the people in the home only have the technical skills to do hard power cycles. A hard powercycle brings it back online successfully with the previous version.
Is there anything else I can do while remote to get this device to take the update successfully and come back online or do I need to hire some kid with a laptop to come to the home and go through the local admin UI/diagnostic tool?
Might the problem be that there are too many versions that passed in between the older working version and the latest?
Do a backup, reboot, restore that backup to clean the database, reboot, then try the update again
