Failed upgrade, now stuck at "Initializing: 70%"
Hi,
I'm using C7 with version 2.3.5.152. Tried to upgrade it to the latest available version, but upon reboot it says that the database is broken. Following some advice on this forum I've downgraded back to 2.3.5.152 and performed a soft-reset. Then, restored the database from a backup I had. The plan was to then try upgrading to the latest version again.
I played with this for a while (upgrading, resetting, restoring, etc.) but it never worked. I'm not stuck in a position where I'm using the old version (2.3.5.152), soft-reset and then restore but when rebooting my hub is stuck at "Initializing 70%: calculating sunrise / sunset".
I've tried rebooting many times, taking out of power for a few minutes, etc. Doesn't work. Any advice?
Edit:
Same issue with 70% initialization also happens when trying to restore an older backup.
Tagging @support_team
Can you PM me the hub id? I'll take a look at the engineering logs, the hub should be cloud connected at 70%.
