I made a cloud backup of my old C7. Then I shut down the C7 and brought up the C8-Pro. When I attempted to restore that cloud backup to the C8-Pro, it brought this error:
"This backup contains ZIP Gateway Z-Wave data, but this hub is using Z-Wave JS. Switch the hub's Z-Wave stack manually, then restore again."
Unfortunately I cannot find any credible info on how to do this on the C8-Pro. Can anyone help me please?
A couple things:
1: In order to switch back and forth on either hub, you go to settings, Z Wave Details, and then click the button to switch back and forth
2:how are you trying to restore the backup? For a migration, you should be selecting "Migrating from another hub" not "restoring" a backup. I believe that handles the issue and sets the correct settings on your C8 Pro (it did on mine just a month or so ago)
