Fade a light from 50% not 100%
I have a rule which fades a light at 10pm. Works great except that the light when turned on is set to 50% so when the fade starts at 10pm the light first jumps to 100% before the fade begins. Is there a way to get the fade to start from the brightness of the light as it is when the fade rule begins?
Could you post a screenshot of post your rule?
Set the light to 50 first and then do the fade.
Typically when dimmer are turned on they will turn on at the last setting when they were turned off.
I did notice that in the latest Zooz FW they have the option of turning on at the last setting of a preset level. Haven’t played with that option yet.
First rule for evening time. It is Living Room Light which jumps to 100%. You can see in the first rule that it is dimmed to 50 when it is turned on.
When time is Sunset-30 minutes
Select Actions to Run
Dim: Living Room Light: 50 Dim: Library Light: 100
Rule at 10pm
When time is 10:00 PM EDT
Fade Library Light, Living Room Light down to 0 over 5 minutes with 10.0 seconds interval
Thanks for looking
