To improve the performance and reliability of the FP300 devices, I added them to M3 hub and pair it to Hubitat C8 pro recently, and it works like a charm. Only downside is temperature sensor is not exposed into Hubitat.
Thinking of making more use of my M3 hub (rather than simply being an intermediary for 3 FP300 devices), I used it as IR blaster for a Dyson fan. However, the added Dyson Fan on M3 Hub does not show up on Hubitat. Is there a workaround?
Would appreciate some advice / thoughts. Thank you.
2/ Created "Scene" in Aqara app - 1 scene for each button of IR remote for fan
3/ In Aqara app, select Profile > Connect to Ecosystems > Matter > Scene and Signal Sync (Limited Trial) > Scene Sync > Add Sync > [choose your scenes] > Add to Matter > Select your M3 hub
4/ Each scene is exposed as a virtual switch in Hubitat
5/ Bonus: This even exposes the Lux sensor on FP300 from M3 hub to Hubitat.
