Hello,
I have about 200+ RM Rules.. just to make a backup of all the rules, I was wondering if there is a "Select All" functionality /check box could be added under the "Export Apps" drop down under the "Export/Import/Clone" page ? or of there is another way to export all apps together at once..
There are multiple thoughts for this..
(1) as a backup before making major changes ( like manually migrating from RM4 to RM5, to be able to use copy paste functionality, etc)
(2) move all the rules from Primary to Backup or Dev hub ( it gets REALLY boring to scroll and click on 200+ checkboxes.. a simple "Select/Unslect all/Toggle" would be extremely helpful.
(3) If I export all the rules, I can open it in notepad and search for "**Broken" and quickly find out of I accidentally removed any device, which had a rule associated with it.. or if I made a mistake accidentally with something else that caused a rule to be broken..
(4) and then combine 1 & 3 to fix the broken rule form a past backup.. if I have saved a copy of all the rules as once they were ..
Thoughts ideas ?
