Expanded on and fixed
ZWave_Classes#Switch_ColorV1
ZWave_Classes#Switch_ColorV2
ZWave_Classes#Switch_ColorV3
Switch Color V1
Command Class: 0x33
Switch Color Supported Get
Command: 0x01
class hubitat.zwave.commands.switchcolorv1.SwitchColorSupportedGet {
List<Short> getPayload()
String format()
Switch Color Supported Report
Command: 0x02
class hubitat.zwave.commands.switchcolorv1.SwitchColorSupportedReport {
boolean amber
boolean blue
boolean coldWhite
boolean cyan
boolean green
boolean index
boolean purple
boolean red
boolean warmWhite
String format()
Switch Color Get
Command 0x03
class hubitat.zwave.commands.switchcolorv3.SwitchColorReport {
String colorComponent
short colorComponentId
String format()
Switch Color Report
Command: 0x04
class hubitat.zwave.commands.switchcolorv1.SwitchColorReport {
short value
String format()
Switch Color Set
Command 0x05
class hubitat.zwave.commands.switchcolorv3.SwitchColorSet {
short colorComponentCount
map colorComponents
String format()
Switch Color Start Level Change
Command 0x06
class hubitat.zwave.commands.switchcolorv3.SwitchColorStartLevelChange {
boolean ignoreStartLevel
boolean upDown
short startLevel
String format()
Switch Color Stop Level Change
Command 0x07
class hubitat.zwave.commands.switchcolorv3.SwitchColorStopLevelChange {
List<short> getPayload()
String format()
Switch Color V2
Command Class: 0x33
Command: 0x01
class hubitat.zwave.commands.switchcolorv2.SwitchColorSupportedGet {
String format()
Command: 0x02
class hubitat.zwave.commands.switchcolorv2.SwitchColorSupportedReport {
boolean amber
boolean blue
boolean coldWhite
boolean cyan
boolean green
boolean index
boolean purple
boolean red
boolean warmWhite
String format()
Switch Color Get
Command 0x03
String format()
Switch Color Report
Command: 0x04
class hubitat.zwave.commands.switchcolorv2.SwitchColorReport {
short value
String format(
Switch Color Set
Command 0x05
map colorComponents
short dimmingDuration
String format()
Command 0x06
boolean upDown
short startLevel
String format()
Command 0x07
String format()
Switch Color V3
Command Class: 0x33
Command: 0x01
class hubitat.zwave.commands.switchcolorv3.SwitchColorSupportedGet {
String format()
Command: 0x02
class hubitat.zwave.commands.switchcolorv3.SwitchColorSupportedReport {
boolean amber
boolean blue
boolean coldWhite
boolean cyan
boolean green
boolean index
boolean purple
boolean red
boolean warmWhite
String format()
Switch Color Get
Command 0x03
String format()
Switch Color Report
Command: 0x04
short targetValue
short value
String format()
Switch Color Set
Command 0x05
map colorComponents
String format()
Command 0x06
boolean upDown
short startLevel
String format()
Command 0x07
String format()
