In one of my rules, if I go to the Select Trigger Events screen the trigger is not displayed and isn't shown in the Edit or Delete drop-downs. I checked a few other rules (with and without required expressions in case that was a factor) and they are not showing this problem.
Anyone seen this and know of a fix aside from recreating the rule?
Yup. I realized that in a moment of unusual (for me) clarity a few minutes ago while I was re-creating the rule. Was coming back to mea culpa/note that, but you beat me to it.
Must be nap time...
Also meant to thank you for this tidbit...we (ambassadors) have been doing these steps separately (and telling others to do them) for a while. Very helpful to understand that is unnecessary.
Super easy to reproduce this problem if you try to create a new rule in rule machine by importing a rule from Simple Automation Rules. After that I can't delete a trigger.
This is the Simple Automation Rule I tried to import:
Interesting, I can reproduce your findings, but only if there are Restrictions in the original SAR. I will track this down, it's a bug in the importing evidently.
Do you think with your fix I will be able to delete the trigger or I will need to start from scratch? Btw cloning the broken rule from Rule Machine created the same issue in the new rule but I guess it was expected...
