Excluded attribute image size of attribute > 1024 - Mobile Device Manager
I have started to get the message Excluded attribute image size of attribute > 1024 characters from the Mobile Device Manager App.
The message goes into the log file when using my iPhone. I see the error when the application is loading on my phone and i also see it when i select the 3 bars in the top left to get the menu.
I have looked at some devices, but cannot find the guilty culprit. Any advice on how to troubleshoot this error message would be appreciated.
I have made many changes and it wasn't doing this when i first migrate to the C8Pro 9-10 weeks ago.
Thanks for your reply...I am NOT using the HUB INFORMATION DRIVER at all...
I did add some static camera images in my dashboard. These images refresh every 5 seconds. They are from my unifi camera system. When i go into the camera dashboard to look at them, i don't get any messages in the log file.
ok...i will test that out...and see where we go...
Not the issue. I removed that dashboard. I also added the cameras to my C7 backup hub and not getting the issue on the other hub...So it is not the cameras.
Thanks for the suggestion
Iā€™d start with any devices that generate an attribute for display.
I've had this issue before. I think (but may be incorrect) this fixes the issue: Go into the phone app in App Settings. Click refresh.
THanks Bill.d This did not work either.
Well i think i have found the culprit devices. They in fact are the UNIFI Cameras...So i have disabled my Unifi Camera devices, and the issues go away. How i fix this i am not sure, but i will post in the appropriate area for this driver...
