Excessively long runtime of HSM Alerts
I recently started having issues with HSM alerts when the system is Armed. I have no issues until it detects an intrusion. Everything will work as far as the siren alerts, lights turning on and what not, except text alerts. I will NOT get any type of alert/notification from HSM about it and the only thing at that time from HSM that is in the logs is a warning saying what triggered it. I also cannot cancel the alerts (to turn off siren, lights, etc) because the HSM app shows nothing happened. However hours later (05:01:49.023 log) all of a sudden I get an alert and HSM has a status of Alert. The logs from 07:04:12.616 was me trying to disarm it from being in Arm Night, it would not disarm or cancel alerts. I had to reboot the hub before I could disarm it. The issue looks like the intrusion handler running too long, ran for 58,856,615ms, but not sure why it is doing that now when it's always worked fine before. The intrusion happened at 2023-01-16 12:40:53.488 PM when the alert actually happened.
This started happening at least 1 version prior.
HV: Rev C-5
PV: 2.3.4.132
app:3  2023-01-17 07:12:59.300 AM  warn   Alert Intrusion canceled
app:3  2023-01-17 07:12:58.266 AM  warn   Alert Intrusion canceled
app:3  2023-01-17 07:12:43.177 AM  info   Disarmed
app:3  2023-01-17 07:10:09.868 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appButtonHandler)
app:3  2023-01-17 07:10:07.693 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appButtonHandler)
app:3  2023-01-17 07:09:30.500 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appArmHandler)
app:3  2023-01-17 07:09:15.249 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appArmHandler)
app:3  2023-01-17 07:09:04.050 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1398 (method appArmHandler)
app:3  2023-01-17 07:08:50.689 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appButtonHandler)
app:3  2023-01-17 07:08:48.144 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1294 (method appButtonHandler)
app:3  2023-01-17 07:08:48.134 AM  warn   Alert Intrusion canceled
app:3  2023-01-17 07:08:27.174 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1294 (method appButtonHandler)
app:3  2023-01-17 07:08:27.163 AM  warn   Alert Intrusion canceled
app:3  2023-01-17 07:07:55.745 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appButtonHandler)
app:3  2023-01-17 07:07:49.507 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1294 (method appButtonHandler)
app:3  2023-01-17 07:07:49.497 AM  warn   Alert Intrusion canceled
app:3  2023-01-17 07:07:37.336 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method updated)
app:3  2023-01-17 07:07:34.444 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appButtonHandler)
app:3  2023-01-17 07:07:24.962 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1294 (method appButtonHandler)
app:3  2023-01-17 07:07:24.951 AM  warn   Alert Intrusion canceled
app:3  2023-01-17 07:07:11.047 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1294 (method appButtonHandler)
app:3  2023-01-17 07:07:11.036 AM  warn   Alert Intrusion canceled
app:3  2023-01-17 07:06:29.166 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method armNoticeHandler)
app:3  2023-01-17 07:06:10.127 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appArmHandler)
app:3  2023-01-17 07:05:54.770 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appArmHandler)
app:3  2023-01-17 07:05:49.860 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appArmHandler)
app:3  2023-01-17 07:05:27.801 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appArmHandler)
app:3  2023-01-17 07:05:05.277 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1294 (method appArmHandler)
app:3  2023-01-17 07:05:05.269 AM  warn   Alert Intrusion canceled
app:3  2023-01-17 07:04:52.337 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appArmHandler)
app:3  2023-01-17 07:04:29.494 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appArmHandler)
app:3  2023-01-17 07:04:19.692 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appArmHandler)
app:3  2023-01-17 07:04:12.616 AM  error  com.hubitat.app.exception.LimitExceededException: App 3 generates excessive hub load on line 1674 (method appArmHandler)
app:3  2023-01-17 05:01:49.023 AM  warn   method intrusionHandlerAway of app Hubitat® Safety Monitor ALERT! ran for 58,856,615ms
app:3  2023-01-17 12:47:42.380 AM  info   Armed Night
app:3  2023-01-17 12:43:35.021 AM  info   Disarmed
app:3  2023-01-16 09:45:00.282 PM  info   Armed Night
app:3  2023-01-16 03:14:11.093 PM  info   Disarmed
I think the newest version (2.3.4.134) may have fixed this. At least it finally worked how it should have today.
