Just thought I would share, I have recently used Gemini for a few apps and have been very happy with the 90-95% (or more) start it's given me from just the prompt. Here is an example, with the prompt I used. All apps so far have run cleanly from the start, and I've also used it to add common things like "timed debug logging".
Prompt
Please make a hubitat groovy app that allows me to select a group of switches and dimmers
which for me will be all the inside house lights, and then between sunset and some time in the
morning (or sunrise) it will turn these lights on and off randomly to mimic someone is home
when the house is empty. This means the lights will turn on and off randomly and not at
exactly the same time because it would take this faux person time to walk around the house. It
would also be good to have less on/off actions past some certain slow down time like
midnight, but still keep a few lights randomly changing.Call the app "Home Alone" and put the author as "Macaulay Culkin".
Also give me:
- a slider from 1 to 10 for how busy the house is
- a way to mark lights that are close to each other and could be turned on very close in timetogether
- debug logging so I can monitor this app's performance easily
- a way to mark which lights are primary lights, since they would be visible from the street the most easily
App
definition(
namespace: "macaulayculkin",
author: "Macaulay Culkin",
description: "Keeps the Wet Bandits at bay by simulating an occupied home with randomized, human-like lighting behavior.",
category: "Safety & Security",
iconUrl: "",
iconX2Url: ""
preferences {
page(name: "mainPage")
def mainPage() {
dynamicPage(name: "mainPage", title: "Home Alone Configuration", install: true, uninstall: true) {
section("The Booby Traps (Lighting Selection)") {
input "allLights", "capability.switch", title: "All Participating Lights", multiple: true, required: true
input "primaryLights", "capability.switch", title: "Primary Lights (Visible from street - higher priority)", multiple: true, required: false
input "groupedLights", "capability.switch", title: "Clustered Lights (Trigger together with a short 2-6s walking delay)", multiple: true, required: false
section("The Schedule") {
input "enableSwitch", "capability.switch", title: "Enable Switch (e.g., a virtual switch tied to 'Away' mode)", required: false
input "startTime", "time", title: "Start Time (e.g., Sunset)", required: true
input "slowDownTime", "time", title: "Slow Down Time (e.g., Midnight)", required: true
input "endTime", "time", title: "End Time (e.g., Sunrise)", required: true
input "busyLevel", "number", title: "Busyness Level (1-10)", range: "1..10", defaultValue: 5, required: true
section("Logging") {
input "debugLogging", "bool", title: "Enable Debug Logging", defaultValue: true
def installed() {
logDebug "Home Alone installed."
initialize()
def updated() {
logDebug "Home Alone updated."
unsubscribe()
unschedule()
initialize()
def initialize() {
schedule(startTime, "startSimulation")
schedule(endTime, "stopSimulation")
// If we update the app in the middle of the night, kickstart it
if (timeOfDayIsBetween(startTime, endTime, new Date(), location.timeZone)) {
startSimulation()
def startSimulation() {
logDebug "Starting Home Alone simulation..."
state.isRunning = true
simulationTick()
def stopSimulation() {
logDebug "Stopping Home Alone simulation..."
state.isRunning = false
logDebug "Turning off all participating lights."
allLights?.off()
def simulationTick() {
if (!state.isRunning) return
if (enableSwitch && enableSwitch.currentValue("switch") == "off") {
logDebug "Simulation paused: Enable switch is off. Checking again in 5 minutes."
runIn(300, "simulationTick")
return
// Determine if we are past midnight/slow down time
def isSlowPhase = timeOfDayIsBetween(slowDownTime, endTime, new Date(), location.timeZone)
// Calculate next run time based on busyLevel (1-10)
def maxDelayMins = (11 - busyLevel) * 4 // Busy 10 = 4 mins max. Busy 1 = 40 mins max.
def minDelayMins = maxDelayMins / 2
if (isSlowPhase) {
maxDelayMins *= 3
minDelayMins *= 3
logDebug "Slow down phase active. Multiplier applied to delays."
def delaySeconds = (new Random().nextInt(((maxDelayMins - minDelayMins) * 60).intValue())) + (minDelayMins * 60).intValue()
// Determine if we should turn a light ON or OFF to maintain realistic capacity
def onLights = allLights.findAll { it.currentValue("switch") == "on" }
def maxLightsOn = (busyLevel / 2).intValue() + 1
def action = "on"
if (onLights.size() >= maxLightsOn) {
// Too many lights on, bias heavily toward turning one off
action = new Random().nextInt(10) > 2 ? "off" : "on"
} else {
// Normal operation, slight bias to turning things on
action = new Random().nextInt(10) > 3 ? "on" : "off"
// Build the pool of valid lights for the chosen action
def pool = action == "on" ? allLights.findAll { it.currentValue("switch") == "off" } : onLights
// Double the weight of primary lights if we are turning a light ON
if (action == "on" && primaryLights) {
pool += primaryLights.findAll { it.currentValue("switch") == "off" }
if (pool.size() > 0) {
def randomLight = pool[new Random().nextInt(pool.size())]
if (action == "on") {
randomLight.on()
logDebug "Turned ON ${randomLight.displayName}"
} else {
randomLight.off()
logDebug "Turned OFF ${randomLight.displayName}"
// Handle Clustered/Grouped Lights
if (groupedLights && groupedLights.find { it.id == randomLight.id }) {
def otherGrouped = groupedLights.findAll { it.id != randomLight.id && it.currentValue("switch") != action }
if (otherGrouped.size() > 0) {
def companionLight = otherGrouped[new Random().nextInt(otherGrouped.size())]
def companionDelay = new Random().nextInt(5) + 2 // 2 to 6 seconds walking delay
logDebug "Clustered light detected. Triggering ${companionLight.displayName} in ${companionDelay} seconds to mimic walking."
runIn(companionDelay, "triggerCompanion", [data: [lightId: companionLight.id, action: action]])
} else {
logDebug "No valid lights to turn ${action} right now."
logDebug "Next movement scheduled in ${delaySeconds} seconds."
runIn(delaySeconds, "simulationTick")
def triggerCompanion(data) {
def light = groupedLights.find { it.id == data.lightId }
if (light) {
if (data.action == "on") light.on() else light.off()
logDebug "Companion light ${light.displayName} turned ${data.action}."
def logDebug(msg) {
if (debugLogging) {
log.debug "Home Alone: ${msg}"
