...and here's something we've never tried before: cut and paste this to a ".json" file, and (I think) you should be able to import it into RM. (EDIT: yup, it worked!)
{"deviceReplacements":{"238":{"deviceName":"Virtual switch","deviceLabel":"TestSwitch","deviceTypeName":"Virtual Switch","deviceTypeNamespace":"hubitat"}},"appReplacements":{"304":{"appTypeName":"Rule-4.0","appTypeNamespace":"hubitat","appName":"Rule-4.0","appLabel":"cumulative time test","parentAppTypeName":"Rule Machine","parentAppLabel":"Rule Machine","singleInstance":false}},"appData":{"304":{"state":{"actionListMain":["1","2","3","4","5","6","10","7","8","9"],"connectors":{},"parens":{"1":0,"2":0},"actionDone":true,"oldConst2":null,"lvt.Trigger":"String","hasRuleAct":false,"selectActionsParams":{"thisStr":"Main","label":"cumulative time test"},"editCondIf":null,"lv.TimePassed":0,"usesTime":false,"inIf":null,"trigCustoms":[],"repeating":[],"capabDone":true,"lastEvtName":"TestSwitch","skippingMain":false,"skipAllMain":null,"locationBlocked":[],"inRepIf":null,"ndx.false":12,"lvList":["TimeOff","TimeOn","TimePassed","TotalTime","Trigger","sdf"],"ruleNdx":4,"firstR":{"1":false,"2":false},"timeTriggers":[],"allVarsO":["ARRIVED","LEFT","sdf","TimeOff","TimeOn","TimePassed","TotalTime","Trigger"],"actLabelIndent":"","howManyT":20,"subscribedVariables":[],"certainTimes":[],"oldConst":null,"prevState":{"PB":"true","Trigger":"off","238":"off","TimePassed":0},"eval":{"1":[3],"2":[6,"OR","2"]},"capabstrue":{"1.true":"TestSwitch(off) turns changed","2.true":"When time is 12:00 AM EST","3.true":{}},"blockIfMain":false,"lastEvtDate":"20-Nov-2020","parenLev":0,"lv.TimeOff":"2020-11-20T00:00:00.000-0500","lv.TotalTime":0,"actionsMain":{"1":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"","rule":0,"label":"Set Trigger to '%value%'\n","cond":0},"2":{"wait":null,"delay":"","modes":{},"method":"getIfThen","indent":"","rule":1,"label":"IF (Variable Trigger(off) = on(F) [FALSE]) THEN\n","cond":0},"3":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"\t","rule":0,"label":"\tSet TimeOn to current time\n","cond":0},"4":{"wait":null,"delay":"","modes":{},"method":"getElseIf","indent":"\t","rule":2,"label":"ELSE-IF (Variable Trigger(off) = off(T) OR \n\tTestSwitch(off) is on(F) [TRUE]) THEN\n","cond":0},"5":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"\t","rule":0,"label":"\tSet TimeOff to current time\n","cond":0},"6":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"\t","rule":0,"label":"\tset TimePassed to minutes of difference between TimeOn(12:00 AM) and TimeOff(12:00 AM)\n","cond":0},"7":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"\t","rule":0,"label":"\tSet TotalTime to (TotalTime + TimePassed)\n","cond":0},"8":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"\t","rule":0,"label":"\tSet TimeOn to current time\n","cond":0},"9":{"wait":null,"delay":"","modes":{},"method":"getEndIf","indent":"","rule":0,"label":"END-IF\n","cond":0},"10":{"wait":null,"delay":"","modes":{},"method":"getSetVariable","indent":"\t","rule":0,"label":"\tIF (Variable TimePassed(0) <= 0 TRUE) Add 1440 to TimePassed\n","cond":9}},"lv.Trigger":"off","nestedInIf":[],"actNdx":12,"installed":true,"lastEvtValue":0,"waitEvents":[],"private":"true","lvt.TotalTime":"Number","lv.TimeOn":"2020-11-20T00:00:00.000-0500","skipTypeMain":"if","gvList":["ARRIVED","LEFT"],"lvt.TimeOff":"Time","hasDevice":null,"ndx.true":3,"editingRule":0,"allVars":{"Trigger":{"val":"off","type":"String"},"LEFT":{"val":"false","type":"Boolean"},"sdf":{"val":null,"type":null},"ARRIVED":{"val":"false","type":"Boolean"},"TimeOff":{"val":"2020-11-20T00:00:00.000-0500","type":"Time"},"TotalTime":{"val":0,"type":"Number"},"TimeOn":{"val":"2020-11-20T00:00:00.000-0500","type":"Time"},"TimePassed":{"val":0,"type":"Number"}},"lvt.TimeOn":"Time","simpleCond":false,"nestedRepIf":[],"nestedBlockMain":[],"lastEvtTime":"10:55 AM","condOper":"cond","formerState":"TimePassed","cutAction":[],"nestedIfMain":[],"nestedLabel":[],"paramNdx":1,"lastEvtDevId":"238","howMany":7,"varUseList":{},"waitCondNdx":2,"token":3,"nestedSkipAllMain":[],"capabsfalse":{"6.false":"Variable Trigger( ) = off","9.false":{},"2.false":"TestSwitch(off) turns changed","10.false":"cond","12.false":{},"3.false":"Variable Trigger( ) = on"},"timeTriggersW":{},"timeFormat":"hh:mm a","waitConds":[],"lvt.TimePassed":"Number"},"appSettings":[{"deviceList":null,"multiple":false,"name":"state9","type":"number","value":"0"},{"deviceList":null,"multiple":false,"name":"valStringOpMain.1Trigger","type":"enum","value":"Set string"},{"deviceList":null,"multiple":false,"name":"state6","type":"text","value":"off"},{"deviceList":null,"multiple":false,"name":"pausRule","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"deleteLv:TimePassed","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"cancelLv","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"state2","type":"string","value":"on"},{"deviceList":null,"multiple":false,"name":"insertAct","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"cond","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"state3","type":"text","value":"on"},{"deviceList":null,"multiple":false,"name":"varType","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"valTimeOpMain.5TimeOff","type":"enum","value":"Now"},{"deviceList":null,"multiple":false,"name":"tstate1","type":"enum","value":"changed"},{"deviceList":null,"multiple":false,"name":"createCon:TimeOff","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"numOpMain.6TimePassed","type":"enum","value":"time difference"},{"deviceList":null,"multiple":false,"name":"valNumberMain.10TimePassed","type":"number","value":"1440"},{"deviceList":null,"multiple":false,"name":"editLv:TotalTime","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"editToken","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"createCon:TotalTime","type":"button","value":""},{"deviceList":{"238":null},"multiple":true,"name":"rDev2","type":"capability","value":null},{"deviceList":null,"multiple":false,"name":"valStringOpMain.11Trigger","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"createCon:TimePassed","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"valTimeOpMain.8TimeOn","type":"enum","value":"Now"},{"deviceList":null,"multiple":false,"name":"rDev9","type":"enum","value":"TimePassed"},{"deviceList":null,"multiple":false,"name":"rDev6","type":"enum","value":"Trigger"},{"deviceList":null,"multiple":false,"name":"rDev3","type":"enum","value":"Trigger"},{"deviceList":null,"multiple":false,"name":"varV","type":"number","value":""},{"deviceList":null,"multiple":true,"name":"logging","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"editCond","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"updateRule","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"hasRule","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"deleteLv:Trigger","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"runAction","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"valVar2Main.7TotalTime","type":"enum","value":"TimePassed"},{"deviceList":null,"multiple":false,"name":"deleteLv:TotalTime","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"locVar","type":"text","value":""},{"deviceList":null,"multiple":false,"name":"rCapab6","type":"enum","value":"Variable"},{"deviceList":null,"multiple":false,"name":"rCapab3","type":"enum","value":"Variable"},{"deviceList":null,"multiple":false,"name":"rCapab2","type":"enum","value":"Switch"},{"deviceList":null,"multiple":false,"name":"numOpMain.10TimePassed","type":"enum","value":"add number"},{"deviceList":null,"multiple":false,"name":"rCapab9","type":"enum","value":"Variable"},{"deviceList":null,"multiple":false,"name":"editAct","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"cutAct","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"rCapab12","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"delayActMain.7","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"delayActMain.6","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"delayActMain.8","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"atTime2","type":"time","value":"00:00"},{"deviceList":null,"multiple":false,"name":"not11","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"delayActMain.1","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"valTimeD1Main.6TimePassed","type":"enum","value":"TimeOn"},{"deviceList":null,"multiple":false,"name":"editLv:TimeOn","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"moreVar","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"delayActMain.3","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"delayActMain.5","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"not12","type":"bool","value":""},{"deviceList":null,"multiple":true,"name":"deleteAct","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"oper","type":"enum","value":null},{"deviceList":null,"multiple":false,"name":"tCapab1","type":"enum","value":"Switch"},{"deviceList":null,"multiple":false,"name":"tCapab2","type":"enum","value":"Certain Time"},{"deviceList":null,"multiple":false,"name":"actionDone","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"actSubTypeMain.9","type":"enum","value":"END-IF"},{"deviceList":null,"multiple":false,"name":"actSubTypeMain.7","type":"enum","value":"Set Variable"},{"deviceList":null,"multiple":false,"name":"actSubTypeMain.8","type":"enum","value":"Set Variable"},{"deviceList":null,"multiple":false,"name":"tCapab3","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"actSubTypeMain.5","type":"enum","value":"Set Variable"},{"deviceList":null,"multiple":false,"name":"actSubTypeMain.6","type":"enum","value":"Set Variable"},{"deviceList":null,"multiple":false,"name":"actSubTypeMain.3","type":"enum","value":"Set Variable"},{"deviceList":null,"multiple":false,"name":"actSubTypeMain.4","type":"enum","value":"ELSE-IF (conditions) THEN"},{"deviceList":null,"multiple":false,"name":"actSubTypeMain.1","type":"enum","value":"Set Variable"},{"deviceList":null,"multiple":false,"name":"actSubTypeMain.2","type":"enum","value":"IF (conditions) THEN"},{"deviceList":null,"multiple":false,"name":"editLv:TimeOff","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"goof","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"valTimeD2Main.6TimePassed","type":"enum","value":"TimeOff"},{"deviceList":null,"multiple":false,"name":"isVar6","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"deleteLv:TimeOff","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"time2","type":"enum","value":"A specific time"},{"deviceList":null,"multiple":false,"name":"actTypeMain.10","type":"enum","value":"Set Mode, Variables or File, Run Custom Action"},{"deviceList":null,"multiple":false,"name":"myVarsMain.11","type":"enum","value":"TotalTime"},{"deviceList":null,"multiple":false,"name":"isVar9","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"myVarsMain.10","type":"enum","value":"TimePassed"},{"deviceList":null,"multiple":false,"name":"actTypeMain.12","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"refreshActions","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"isVar3","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"myVarsMain.1","type":"enum","value":"Trigger"},{"deviceList":null,"multiple":false,"name":"hasAll","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"myVarsMain.3","type":"enum","value":"TimeOn"},{"deviceList":null,"multiple":false,"name":"cancelCapab","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"updateV","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"myVarsMain.6","type":"enum","value":"TimePassed"},{"deviceList":null,"multiple":false,"name":"myVarsMain.5","type":"enum","value":"TimeOff"},{"deviceList":null,"multiple":false,"name":"myVarsMain.8","type":"enum","value":"TimeOn"},{"deviceList":null,"multiple":false,"name":"myVarsMain.7","type":"enum","value":"TotalTime"},{"deviceList":null,"multiple":false,"name":"delayActMain.10","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"origLabel","type":"text","value":"cumulative time test"},{"deviceList":null,"multiple":false,"name":"eraseRule","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"numOpMain.11TotalTime","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"editLv:TimePassed","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"editLv:Trigger","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"delete","type":"enum","value":""},{"deviceList":null,"multiple":false,"name":"numOpMain.7TotalTime","type":"enum","value":"variable math"},{"deviceList":null,"multiple":false,"name":"valStringMain.1Trigger","type":"textarea","value":"%value%"},{"deviceList":null,"multiple":false,"name":"RelrDev6","type":"enum","value":"="},{"deviceList":{"238":null},"multiple":true,"name":"tDev1","type":"capability.switch","value":null},{"deviceList":null,"multiple":false,"name":"RelrDev9","type":"enum","value":"<="},{"deviceList":null,"multiple":false,"name":"actionCancel","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"createCon:Trigger","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"createCon:TimeOn","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"RelrDev3","type":"enum","value":"="},{"deviceList":null,"multiple":false,"name":"valMathOpMain.7TotalTime","type":"enum","value":"+"},{"deviceList":null,"multiple":false,"name":"actTypeMain.9","type":"enum","value":"Conditional Actions"},{"deviceList":null,"multiple":false,"name":"comments","type":"textarea","value":""},{"deviceList":null,"multiple":false,"name":"valVarMain.7TotalTime","type":"enum","value":"TotalTime"},{"deviceList":null,"multiple":false,"name":"actSubTypeMain.10","type":"enum","value":"Set Variable"},{"deviceList":null,"multiple":false,"name":"valTimeOpMain.3TimeOn","type":"enum","value":"Now"},{"deviceList":null,"multiple":false,"name":"not6","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"varValue","type":"textarea","value":null},{"deviceList":null,"multiple":false,"name":"not3","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"useCondMain.10","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"deleteLv:TimeOn","type":"button","value":""},{"deviceList":null,"multiple":false,"name":"not9","type":"bool","value":""},{"deviceList":null,"multiple":false,"name":"actTypeMain.2","type":"enum","value":"Conditional Actions"},{"deviceList":null,"multiple":false,"name":"actTypeMain.1","type":"enum","value":"Set Mode, Variables or File, Run Custom Action"},{"deviceList":null,"multiple":false,"name":"actTypeMain.4","type":"enum","value":"Conditional Actions"},{"deviceList":null,"multiple":false,"name":"actTypeMain.3","type":"enum","value":"Set Mode, Variables or File, Run Custom Action"},{"deviceList":null,"multiple":false,"name":"actTypeMain.6","type":"enum","value":"Set Mode, Variables or File, Run Custom Action"},{"deviceList":null,"multiple":false,"name":"actTypeMain.5","type":"enum","value":"Set Mode, Variables or File, Run Custom Action"},{"deviceList":null,"multiple":false,"name":"actTypeMain.8","type":"enum","value":"Set Mode, Variables or File, Run Custom Action"},{"deviceList":null,"multiple":false,"name":"actTypeMain.7","type":"enum","value":"Set Mode, Variables or File, Run Custom Action"}],"subscriptions":[{"handler":"allHandler","name":"switch","type":"DEVICE","typeId":238,"typeName":"TestSwitch","filter":"true"}]}}}
