I have a C5 hub in my shop which is about 200' behind my house. Yesterday while at work I lost connection to the shop HE hub,It is connected to my house hub via hubconnect. I did have connection to my main hub in the house. I figured my CPE device that connects my house wifi to the shop had lost connection again, as it will do from time to time.
When I got home I reset the CPE but I still could not access the hub, I then realized that the bridged router in the shop was available along with other devices, so the wifi connection was good. I then opened up my router and found that it showed the shop hub connected but it was showing the wrong IP. If fact it wasn't even an IP that should be on my network. I have it set for a fixed IP so I don't know how it changed. It should have been 192.168.1.xx but it was something like 264.953.something. something. I guess I should have wrote it down, but i just powered down the hub and restarted. It then came back on the correct IP and was working.
This is the only time this has ever happened but it was weird.
