Event Engine Cog Examples
- Keen Vents -
Event Engine Cog (2.5.1) - Living Room Vents
Conditions
***** Cog will fire when ALL Condition are true (Using AND)
- By Temperature Setpoints: [AP - Living Room Temp on Home] - setpoint High: false NA, setpoint Low: true 70
- Rolling Average: false - Use Whole Numbers: false - ResetTime: NA
Actions
- Dimmers to Set: [Living Room Vent - Under Window on Home, Living Room Vent - Wall on Home] - On Level: 75 - Color: NA - Temp: NA
- Reverse High: false - Reverse Low: true - Reverse Between: false
- Use Permanent Dim: true - PD Level: 10 - PD Color: NA - Temp: NA
- Delay Between Actions: 250
