Errors in the logs after update to 2.3.3.121
I just updated to 2.3.3.121 and I noticed the following errors in my logs...
dev:2072022-09-23 02:02:24.120 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
dev:2072022-09-23 02:01:14.103 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
dev:2072022-09-23 02:00:04.311 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
dev:2072022-09-23 01:58:54.102 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
dev:8952022-09-23 01:58:15.466 pminfoEcho (v4.2.0.7) | Echo - Echo Show Executing initialize()
app:11512022-09-23 01:58:00.709 pminfo EchoApp (v4.2.0.7) | running initialize...
dev:2072022-09-23 01:57:44.086 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
dev:2072022-09-23 01:56:34.102 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
dev:2072022-09-23 01:55:24.118 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
dev:2072022-09-23 01:54:14.102 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
dev:2082022-09-23 01:53:47.723 pminfoServer Room Temp Sensor temperature is 83.88°F
dev:2072022-09-23 01:53:04.086 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
dev:2072022-09-23 01:51:44.118 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
dev:2072022-09-23 01:50:34.171 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 207 generates excessive hub load on line 544 (method connectDevice)
app:4342022-09-23 01:50:30.792 pminfoParent Installed OK
app:4342022-09-23 01:50:27.991 pminfoHoneywell API Token Refreshed Succesfully, Next Scheduled in: 1699 sec
dev:3002022-09-23 01:50:20.423 pmerrorcom.hubitat.app.exception.LimitExceededException: Device 300 generates excessive hub load on line 457 (method parse)
app:4342022-09-23 01:50:06.069 pminfoParent Installed OK
Chris
Which devices are these? This check/error is new for 2.3.3 and indicates that particular device is using too much of the hub's CPU time.
If I click on the dev207 it consolidates to this...
dev:2072022-09-18 03:18:02.363 aminfoMagicHome (10.200.0.93): Connection successfully established
Oddly enough the SHOW MORE button on the bottom does not return the log list to the normal state
If you click on the red error bit instead, it will take you to device details.
Also, check Logs page, Device stats tab. There should be some busy devices at the top.
Its the MagicHome Wi-Fi Controller
I guess I should send a note to the developer of the app.
It was most likely always like this but the new features pointed it out.
%of Busy for this device is up tp 70%
Weird... I have like 3 more of the same exact devices and they all show around 6%
Let me try power cycling the actual device.
Hi!
Getting the same with the Shelly Wifi drivers:
dev:252022-09-29 16:42:15.370errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 169 (method configHandler)
dev:252022-09-29 16:42:15.274warndescription logging is: true
dev:252022-09-29 16:42:15.271warndebug logging is: false
dev:252022-09-29 16:42:15.269infoupdated...
dev:222022-09-29 16:41:55.983errorException when sending: status code: 400, reason phrase: Bad Request. Please check your device settings.
dev:222022-09-29 16:41:54.893warndescription logging is: false
dev:222022-09-29 16:41:54.891warndebug logging is: false
dev:222022-09-29 16:41:54.888infoupdated...
app:712022-09-29 16:41:38.418warnDevice InfluxPost triggered a forced post, writing to DB
dev:272022-09-29 16:41:33.144errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 44 (method parse)
dev:262022-09-29 16:41:33.033errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 44 (method parse)
dev:272022-09-29 16:41:32.021errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 44 (method parse)
dev:272022-09-29 16:41:30.981errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 44 (method parse)
dev:272022-09-29 16:41:29.931errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 44 (method parse)
dev:262022-09-29 16:41:29.919errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 44 (method parse)
dev:132022-09-29 16:41:23.066errorcom.hubitat.app.exception.LimitExceededException: App 12 generates excessive hub load on line 82 (method on)
dev:132022-09-29 16:41:02.362errorcom.hubitat.app.exception.LimitExceededException: App 12 generates excessive hub load on line 82 (method on)
dev:12122022-09-29 16:40:46.844infoTest Repeater: Humidity is 46.9%
dev:12122022-09-29 16:40:46.295infoTest Repeater: Temperature is 26.8°C
dev:132022-09-29 16:40:37.643errorcom.hubitat.app.exception.LimitExceededException: App 12 generates excessive hub load on line 82 (method on)
dev:132022-09-29 16:40:35.656errorcom.hubitat.app.exception.LimitExceededException: App 12 generates excessive hub load on line 82 (method on)
dev:272022-09-29 16:40:30.195errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 44 (method parse)
dev:262022-09-29 16:40:30.177errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 44 (method parse)
dev:272022-09-29 16:40:30.158errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 44 (method parse)
dev:262022-09-29 16:40:30.140errorcom.hubitat.app.exception.LimitExceededException: Device 25 generates excessive hub load on line 44 (method parse)
In Logs page, Device stats tab, what are the numbers for those Shelly devices?
Also, does it happen immediately after a reboot?
