Errors for built-in driver for Sonoff Zigbee devices
I have a number of the Sonoff Zigbee devices that are giving the following error in the logs,
Groovy.lang.MissingMethodException: No signature of method: sonoffZigbeeContact.recoveryEvent() is applicable for argument types: () values: [] (recoveryEvent)
Is this something I should be concerned about? I found this while trying to troubleshooting issues with my zigbee network going offline
What driver are you using?
Did you used to use the diver from Markus?
If you scroll to the bottom of the driver page do you see scheduled events?
If you are not using bis driver and have scheduled events you can change the driver to 'Device'.
Click on stop scheduled events.
Then swap back again.
Yes I did used to use the one from markus but wanted to give the built-in one a try...
I will give this a go thank you!
No problem.
The error doesn't hurt but I agree it is nice to get rid of it.
I figured as much, but I don't like seeing the red errors :slight_smile:
