I'm not getting humidity readings from a sensor I'm playing with, and I've found this error in the logs and it doesn't look like the device handler issues I've managed to cause.
dev:352018-08-26 15:27:54.203:errorgroovy.lang.MissingMethodException: No signature of method: GenericZigbeeMoistureSensor.getHumidityResult() is applicable for argument types: (java.math.BigDecimal) values: [67.79] (parse)
Can anyone give me a hint on where I might start investigating?
The generic zigbee moisture sensor is specifically for water detection, it's not capable of detecting humidity, it is however hitting a unimplemented section of humidity parsing.
We don't have a dedicated single function driver for humidity as there are very very few of them.
In any event give the NYCE Motion Sensor Series driver a try, your device obviously isn't going to provide any motion but it may provide temperature and humidity readings.
Be sure to hit configure in the driver to set the reporting parameters.
Right, that worked perfectly. Seems I didn't fully engage the brain when I read 'moisture sensor', but I'm well pleased to have found a driver that gets the job done. Thanks for the help.
