Error with Hue Bridge Integration after 2.1.4 update
I don’t know if this is anything important, but I have the following error in the logs under Hue Bridge Integration after updating to 2.1.4
app:22019-08-22 09:25:28.321 amerrororg.h2.jdbc.JdbcSQLException: Column "name" not found [42122-197] on line 1096 (putHandler)
--- Loading Past Logs... ---
At what moment do you get that error? And is your hue hub up-to-date? Because i'm not getting that error.
I’m applying the update. I’ll see if the error reoccurs.
It hasn’t happened since the last hub reboot
