Error thrown by Generic Zigbee Outlet
I have a number of these cheap but okay Zigbee outlets. One of the four has started generating errors in the logs. AFAIK it still works. Wondering if this is revealing a bug in the driver.
Error:
org.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: GenericZigbeeOutlet.deviceHealthCheck() is applicable for argument types: () values: (method deviceHealthCheck)
Device info:
I was about to replace this one but thought I'd post in case it has revealed a latent coding error.
Jay
This is not a bug; it is a scheduled job from another driver you tried. Just delete the scheduled job.
That did it. I had to switch to the "Device" driver first so I could issue that command. Then switched back. Thanks!
