I've tried to use the new feature (in 2.0.9.133) of setting a virtual temperature sensor value to a GV but get a "Parameters: ** bad value **" error. The GV is set as decimal and has a valid value as can be seen below.
Yes, there is a bug for decimal values. Will be fixed in the next release.
