Error on Shelly Wave 1 PM
Good Day,
I just installed a Shelly Wave 1 PM to control a light that was wired through an old pull switch on the light fixture itself. I have changed out this old "pull chain" switch fixture for a plain fixture and then wired up the Shelly. I selected a virtual device and selected the Wave 1 PM. However, I am getting an error; 'For input string: "d8176ba4-2926-44c7-9e34-af318d247bbb", and I have no idea what this is. Can someone clarify what this is and how I go about fixing the issue?
Thanks in advance.
Cheers
This is the log from the Wave 1 PM;
dev:8452025-04-15 06:33:44.086
error
For input string: "e2bec64c-2183-4b38-8315-34ccdd1a5ef3"
dev:8452025-04-15 06:33:44.077
debug
Big Bedroom Closet light 1 sendCommands Command(200100)
dev:8452025-04-15 06:33:44.073
trace
Big Bedroom Closet light 1 supervisionEncap(): BasicSet(value:0)
dev:8452025-04-15 06:33:44.054
debug
Big Bedroom Closet light 1 off()
dev:8452025-04-15 06:33:07.421
error
dev:8452025-04-15 06:33:06.919
error
dev:8452025-04-15 06:33:06.417
error
dev:8452025-04-15 06:33:05.915
error
dev:8452025-04-15 06:33:05.413
error
dev:8452025-04-15 06:33:04.911
error
dev:8452025-04-15 06:33:04.409
error
dev:8452025-04-15 06:33:03.907
error
dev:8452025-04-15 06:33:03.406
error
dev:8452025-04-15 06:33:02.902
error
dev:8452025-04-15 06:33:02.400
error
dev:8452025-04-15 06:33:01.899
error
dev:8452025-04-15 06:33:01.397
error
dev:8452025-04-15 06:33:01.385
debug
Shelly Wave 1PM sendCommands Commands([2502, 700501, 700511, 700513, 700514, 700517, 700519, 700524, 700527, 70055B, 70055C, 70055D, 70055E]), delay (500)
dev:8452025-04-15 06:33:01.321
info
Shelly Wave 1PM refresh()
dev:8452025-04-15 06:32:51.304
info
installed(1.2)
The Wave 1 PM is a Z-Wave device. You need to add the device to your hub like you would any Z-Wave device, not as a virtual device:
Or do you have a different model?
no, it is a Wave 1 PM. I will factory reset it and then do an inclusion and see how it goes.
Cheers
