Error message from Sonoff Motion and Temp
Getting these messages from my Sonoff Motion and Temp sensors. They both still work but wanted to know if I need to fix them or repair them?
Any thoughts?
Added: Using the stock drivers for both 'The Generic Zigbee Motion Sensor (no temp) for the motion and the Sonoff Zigbee Temperature/Humidity Sensor for the other'
Temp:
Motion:
What driver are you using if it is the hubitat one's, what driver where you using?
What driver are you using? Did you switch to a Hubitat stock driver after using a community driver (the one by Markus, which does have those methods and schedules checkEventInterval on a regular basis, hence my suspicion)? If so, try switching to the plain "device" driver in between and run the command to delete all scheduled jobs (clearing state and whatnot wouldn't hurt either), then switch back.
Ah sorry should have said which driver! My apologies, The Generic Zigbee Motion Sensor (no temp) for the motion and the Sonoff Zigbee Temperature/Humidity Sensor for the other. (Stock Drivers.
Will try the above and see how it goes thank you very much :+1:
Thank you both @mark.cockcroft and @bertabcd1234 for your speedy reply. I think the Device clearing trick worked, also the motion sensor appears to work faster as well. Marked as solved.
Many thanks :blush:
