Error logs
Hi, i tried to delete the 2nd line of my action. "If skylight switch is off". Now my rule won't run and I have the below error log. Is there a way to fix this guys or do I need to rewrite the rule. Cheers Guys
It's going to be quicker to just rewrite it.
You'll always have that nagging doubt in the back of your mind if you somehow fix it. :smiley:
I think you're correct. I've learnt on my short journey that's it's prudent to clone a rule before I alter it. RM has done this a few times to me now. Thanks again :+1:
You removed the IF did you remove the corresponding END-IF?
Hi, I can't recall now and I've deleted the rule. However, I'll definitely, ensure I delete the END IF in the future. Sound advice and thanks for your help. It's very appreciated :+1:
