Error loading Zooz drivers- SOLVED
Hello. I have a C-8 running 2.5.1.152, as well as a C-8 pro. The pro has had zooz device drivers loaded onto it for some time, and I wanted to do the same to the C-8. However, when I paste either of them in and hit save, I get the message below. Interestingly enough, the user driver shows up as a choice on the device tab, but isn't actually able to be saved to the drivers. Any guidance would be appreciated.
Thanks,
Stephen.
java.sql.SQLException: General error: "org.h2.mvstore.MVStoreException: Writing to sun.nio.ch.FileChannelImpl@e56955 failed; length 8192 at 0 [2.2.224/2]"; SQL statement: SELECT DTCL.DEVICE_TYPE_ID, C.ID AS CAPID, C.NAME AS CAPNAME, A.ID AS ATTRID, A.NAME AS ATTRNAME, COM.ID AS COMID, COM.NAME AS COMNAME FROM CAPABILITY C JOIN DEVICE_TYPE_CAPABILITY_LINK DTCL ON DTCL.CAPABILITY_ID = C.ID LEFT JOIN ATTRIBUTE A ON A.CAPABILITY_ID = C.ID LEFT JOIN COMMAND COM ON COM.CAPABILITY_ID = C.ID ORDER BY DTCL.DEVICE_TYPE_ID, C.ID, A.ID, COM.ID [50000-224] Query: SELECT DTCL.DEVICE_TYPE_ID, C.ID AS CAPID, C.NAME AS CAPNAME, A.ID AS ATTRID, A.NAME AS ATTRNAME, COM.ID AS COMID, COM.NAME AS COMNAME FROM CAPABILITY C JOIN DEVICE_TYPE_CAPABILITY_LINK DTCL ON DTCL.CAPABILITY_ID = C.ID LEFT JOIN ATTRIBUTE A ON A.CAPABILITY_ID = C.ID LEFT JOIN COMMAND COM ON COM.CAPABILITY_ID = C.ID ORDER BY DTCL.DEVICE_TYPE_ID, C.ID, A.ID, COM.ID Parameters: []
I'd start with a database rebuild:
  1. Go to Settings > Reboot.
  2. Enable Show advanced options.
  3. Enable Rebuild database on reboot (which will appear after the above)**.
  4. Select Yes to perform the reboot, wait a few minutes for the hub to come back up, and try again.
Ding ding! Thank you.
