Error installing Kasa through HPM
Ok, new to Hubitat, and from what I've seen in the community, I'm on the wrong tail end of the programming knowledge level, so apologies if this is basic.
I can't get David G's Kasa to install. I keep getting a login error.
" Error logging in to hub
An error occurred logging into the hub. Please verify your Hub Security username and password."
I started setting up my hub this morning. Paired with a smartthings water sensor, no prob. THought maybe I should enable the user login, so I set a username and pw. I installed the HPM to get to the Kasa integration. When the hubitat rebooted, I couldn't get back into, so I went through the portal and disabled the login requirement. Still no joy installing the kasa integration. Thoughts on what I did and how to fix it? Also, is there a list of best practices regarding security and network setup? I'm not strong on the IT side. Thanks!
You can install the integration manually while you figure out the issue with HPM (I think that is where the problem is, but, outside my lane).
Site link is HubitatActive/KasaDevices at master ยท DaveGut/HubitatActive ยท GitHub.
Manual installation instructions: HubitatActive/Documentation.pdf at master ยท DaveGut/HubitatActive ยท GitHub
Note, the installation instructions. Some of the functional data is dated.
Dave
Look in the HPM settings, you will have to enter your hub's security info (or remove). It's just because HPM can't access the hub to do what you asked it to do (install Kasa).
I would give you screen shots but not home at the moment.
Check this post and a few under it about this error...
You can also post in that thread for a faster response on this problem.
