Error in package manager
@Johndc7 I happened to be looking at my logs this morning and package manager came back with the following. Don't know if you need to do anything
app:512021-02-26 12:00:01.923 am errorBad manifest for Presence Sensor. java.lang.NullPointerException: Cannot get property 'betaLocation' on null object Please notify the package developer.
app:512021-02-26 12:00:01.919 am errorError downloading https://raw.githubusercontent.com/johndc7/Hubitat/main/presence-sensor.json: groovyx.net.http.HttpResponseException: Not Found
I moved that file to a different repo a couple months ago. Maybe try running the match up in HPM again?
Possibly. I'll run an update. Just wanted to let ya know :slight_smile:
Yea I think that's what is was. Thanks :slight_smile:
So after doing a full refresh of everything, when I clicked update on presence sensor I got this
Hmm... I did a backup of my Hubitat, removed all Presence Sensor stuff and started over. When I went to install it, everything went as expected. You can try uninstalling HPM / removing the code for Presence Sensor manually and reinstalling. Maybe it would be better to ask @dman2306 since it seems to be an HPM issue.
The author of the package maintains the manifest. You might need to talk to that developer to take a look.
I am the author of the package lol
Everything seems to work for me and I double checked to make sure all of my links are ok. Here is a link to my repository.json in case you want to double check anything.
It’s not an invalid json issue.
Well that's not actually the manifest file, https://raw.githubusercontent.com/johndc7/Presence-Sensor/master/package.json is but that also looks OK.
@rlithgow1 hat error occurs only if the file is invalid or couldn't be downloaded for some reason. Maybe it was just a network hiccup? Logs when it happens would also be helpful.
