Error in logs for dashboard
I have the following error in my logs. It showed up a few days ago. Nothing has changed on my end... no new apps, drivers etc. I have already tried 2 soft resets and the problem persists. Any advice? It's listed as app 4 which directs me to my dashboards app.
org.h2.jdbc.JdbcSQLException: Column "name" not found [42122-197] on line 123 (getDevices)
Usually SQL errors are hub database problems. If you have a known-good backup (locally saved or from Settings > Backup and Restore), you could try that. I'm guessing you had to restore after your reset anyway, but the question would be whether the backup is from a "good," pre-error copy.
If this doesn't help or you're not sure, I'd recommend reaching out to Hubitat Support. They just posted that they're pretty busy with lots of new tickets at the moment, so I'd try whatever you're willing to first to see if you can solve it on your own.
While I have not gotten that error, it appears to be pretty common. You can search this site for 'column name' and see a lot of hits. I don't know if that will help you resolve the problem. @bobbyD is your best bet (Support@Hubitat.com).
Thanks guys. I did a few searches which is where i found the soft reset idea. Nothing is really going wonky other than running a little bit slower than usual sometimes. I'll get a ticket opened.
