I created this rule:
When I click Done with Actions it changes it to:
If you notice it changes the second expression to be the same as the first one.
Is it not allowed to have two different expression in the same rule?
This could be a bug. I will investigate...
I'm not able to get this failure. Please show the Manage Conditions block, like this:
And also, please show two lines from the Application State of the App Status page (gear icon): the value for capabsfalse
, and the value for eval
Here's what I get:
then
That's as it should be.
Please show the portion of Application State that shows actionList
and actions
I cannot reproduce this problem. I suggest that you remove that rule, and recreate it. If that repeats the issue, let me know.
That's not right. What release are you on? Is this Rule 5.1?
Yes, 5.1 and
Platform Version
2.3.1.129
Hardware Version
Rev C-5
I recreated it, and it seems fine, but it's different: Now I have "Cancel Delayed Actions", rather than "Timed Actions" - and I'm not sure what the difference is between them, or why I got one vs. the other.
Does canceling delayed actions mean it cancels the delay (i.e. it starts running right away), or does it stop the rule and any further actions? Basically I want to handle someone locking/unlocking the door multiple times with 2 minutes.
BTW I kept the other rule in case it helps you for debugging and tried editing the Conditional, and it always sets both conditions to the same thing.
What version of Rule is this? Does it show a version number? Rule 5.1?? Like this:
Version 5.1.2 (3/16/2022)
